Installation Of The Adobe Acrobat Software Shows Acrobat Error 1324
The corrupted installation file of the acrobat application causes Acrobat error 1324. The error message ‘Error 1324: The path Windows or the volume is invalid. Please enter it again is due to a corrupt installation.’
Firstly, the user needs to remove or uninstall the corrupted installed file. The easiest way to do that is to download the Acrobat Cleaner Tool. Once the tool is downloaded, then install the file, and run the tool, and select “Acrobat” from two options. When the clean-up of the system is completed, then a message will appear saying, “Adobe Acrobat has been successfully removed from the machine. Please reboot your machine to complete the clean-up.”
After a successful reboot of the system, re-install the application file, and it will be installed
