Burton Tag
Posted on - 11/05/2020
What is the 0x8024402 error? Why Windows Server Update Service gives out this error and explains the steps to resolve this error code.
Installation Of The Application From The Store Throws 0xc8000222 Error. Can, Anyone Give Me A Detailed Explanation?
0x8024402 error is a WSUS (Windows Server Update Service) error that occurs in the computer as well as it also occurs to the devices which receive the update from the Windows Updates servers. Windows corrupted or out of date drivers are the reason for the occurrences of this error code. The first thing to do is to get the device hardware driver from the hardware manufacturer, and this will help to get the correct version of the driver for the system. The solutions to fix the 0x8024402 error code are as follows:
Method 1:
Check for Malware.
MalwareBytes and SuperAntiSpyware are two of the famous antivirus program that users can download, install, run, update, and perform full system scans.
Then execute an online scan with the eSet Online Scanner and restart the system.
Method 2:
Reset Windows Update Components.
Start Command Prompt as administrator. Run the commands:
- net stop wuauserv
- cd %systemroot%
- ren SoftwareDistribution
- old
- net start wuauserv
Now, reboot your system and try for the update.
