Installation Of The Certificate Authority, For Allowance Of Server Connections
Give a detailed description of the installation of the certificate authority and add the screenshot of the necessary steps.
A certificate verifies the private computer to enter into a secure server. The following steps will tell about the installation of certificate authority in the system:
• Start Control Panel.
• Go to Add/Remove Programs applet.
• Click on Add/Remove Windows Components to start the Windows Components wizard.
• Now click on Next.
• Select the certificate services checkbox and click Next.
• Now, select Enterprises root CA and click on Next.
• Now, enter the required information and click on Next.
• Click on Next.
• If Microsoft IIS is running, the services will stop, and the window will come on screen. Click OK.
• A list of files will appear and start installing in the system.
• At last, click on Finish.
