Installation Of The .NET Framework Application Throws 0xc8000222 Error
Share your thoughts on the 0xc8000222 error? Explain the error code briefly and show the steps to fix this error code and add the snapshot of the error?
0xc8000222 error is an installation error that occurs when the user installs dot net framework 4. The cause for the occurrence of the error is the corrupted files in the Software Distribution folder. The error code displays “.NET Framework 4 failed to install because of error code HRESULT: 0xc8000222.”
Try to install the update manually by using command prompts as directed below:
Step 1: Click on Start > Run.
Step 2: Type cmd and press Enter.
Now, type the following command:
net stop Wuauserv
Step 3: Now, click on Start > Run then type %windir% and press Enter.
Step 4: Rename the SoftwareDistribution to SDold.
Step 5: Click on Start > Run then type cmd and press Enter.
Now, run the following command:
net start wuauserv
If the problem still occurs then right-click on the cmd.exe and run it as administrator.
Notifications
