An installation package for the product Topaz Lens Effects cannot be found
80 points
Posted on - 10/24/2012
The problem is with Topaz Lens Effects i.e. the Photoshop plug-in simulates lens, the filter and the camera effects.
I received an error message while installing the same. I tried several way but failed. It failed to find an installation package.
I do not understand the error message.
Have you any idea for the problem?
Please help.
Topaz Lens Effects
An installation package for the product Topaz Lens Effects cannot be found. Try the installation again using a valid copy of the installation package ‘bokeh_setup.msi’.
