Installation problem with from CD
Hi guys,
I tried several times to install Ubuntu from a CD.
But after Asus Screen, the screen always went blank which did not react to any keys and there was no error code.
What should I do to install Ubuntu?
Hi guys,
It may be problem with your CD. Check your CD in other computer. If it shows same problem, then your CD have been damaged. You can use USB flash drive to install Ubuntu. I think it’s the easiest way.
Use “Linux Live CD Creator” to make your flash drive bootable. At first download .iso file from https://www.ubuntu.com/ then open Linux Live creator. Select your .iso file & make your USB bootable.
You need to change setting of your bios to boot from USB.
Press F12 before boot screen. Then change your boot priority. Change it to “USB flash drive”.
Now its done. You can install Ubuntu from your USB pen drive
Notifications
