Installation problem of Fix-It Utility Pro 11
Hi everyone,
I wanted to install Fix It in my pc, my operating system is Windows XP. According to the manual of Fix-It, I need to turn off any other antivirus software, but when I ran the installer, it mentioned that I have to uninstall the antivirus of my system. I turned off my antivirus by entering to Security centre in XP and selecting all components off, but still I was unable to do the registration. Can anyone suggest me the solution? I would be grateful for that.
