The installation process cannot be resumed
Hi guys, My post here is about the problem I encountered while installing Nero Kwik Media, in the middle of the installation process I received an error message, that is telling me that there are some components that cannot be installed, while others are successfully installed, and it will roll back the installation process.
Nero Kwik Media- The installation process cannot be resumed. A rollback of the failed component will be performed. Some applications have been installed successfully and can be used. Do you want these applications to be uninstalled?
I keep on repeating the process all over again with same error I meet, until I replaced my installer with another copy, but unfortunately the same error message will be given to me, please share you ideas on this error message that i received, thanks a lot.
