I am trying to install SolidWorks 2012, student version on my windows 7, 64 bit machine. I install proceeded till 29% when it stopped and threw out an error “RollbackUnReg_DocMgrDLLxxxxxx”. I uninstalled the program and installed it again and getting the same error on another percentage. I tried to get the correct Visual C++ Redistributable x64 package and installed but of no joy. Please help.
SolidWorks Installation Manager
Internal Error: The Windows Installer for this product component did not run as expected: RollbackUnReg_DocMgrDLL.xxxxxxxxxx.
Contact Technical Support.
When contacting Technical Support about installation issue, you will need to provide the installation log files available in this directory. Use the button below to save your logs as a zip file for sending to your support representative.
Installation shows error while installing SolidWorks 2012
Well, in order to install this do you have enough disk space or do you have administrative rights on the computer? One thing, you should not post the log files in a public forum as they contain the serial numbers for SolidWorks and associated modules.
Or, what you do is open your DVD case and take out the 64 bit version DVD, insert into the DVD drive and let this run. Else, copy the entire contents of the DVD onto your HD and try installing it from there. But before you do this, clean out the registry.
Before installing SolidWorks 2012, make sure your computer meets the requirements. SolidWorks 2012 supports Windows XP, Windows Vista, and Windows 7. Microsoft Windows 8 and Microsoft Windows 10 are not supported. SolidWorks 2012 requires an Intel or equivalent AMD processor with SSE2 support, 2 GB RAM, and 5 GB free space. If this doesn’t work, try installing the latest Windows Installer for your operating system.
You can do this by updating your operating system to the latest Service Pack. For Windows XP, download Windows XP Service Pack 3. This is the latest and last Service Pack update for Microsoft Windows XP. For Windows Vista, download Windows Vista Service Pack 2. This is the latest and last Service Pack update for Microsoft Windows Vista.
For Windows 7, download Windows 7 Service Pack 1. This is the latest and only Service Pack update for Microsoft Windows 7.
