Laura T
Posted on - 10/14/2011
Hello, I need help with the installation of Soluto Anti-frustration Software.
I tried to install it a couple of times but every time the same error message is displayed: "Soluto’s Installer
Soluto’s installation has encountered an unexpected error:
[Error] 1603, Fatal error during installation.
Please contact [email protected] to resolve the issue"
I have no idea what I’m doing wrong, but if anyone could help I would appreciate it very much.
Thanks for any provided info.
Installation of Soluto Anti-frustration Software
It is better to contact with [email protected] as it already told you to contact with them. So try that first if it doesn’t help, and then try to copy the software installation files from the CD or DVD if you have and try to re install it.
If the installation file comes from internet OK then download it again and try to re-install it.
See the requirement of the software and see the capability issue that’s mean whether the software is capable or not with your windows or OS.
If you have threats in your computer that another cause that make problem then try to scan with the antivirus and fix it.
It could be that the program is corrupted and it might not support your current operating system or there are some files missing or needs to be fixed.
Solution 1:
Try downloading the said program again the is compatible to your operating system. Just simply search the internet. Then once you download it try installing it again in your PC.
Solution 2:
You could just simply contact their support team together with the error log on your computer. Or just simply send them the error that you encountered on your computer. It is best to ask them because they know better than anyone of us.
