Installation steps of Win xp driver Mac leopard
I want to install Win XP driver in Mac leopard OS which is compatible with Apple macbook pro. Can someone provide me the drivers as well as the steps of Installation?
Hello there.
You'll need a software called Boot Camp to do this. You can get bootcamp here:
http://download.cnet.com/Apple-Boot-Camp-Support-Software/3000-18513_4-93144.html
The installation steps for windows xp in mac leopard os are to:
1.      Run the boot camp assistant application. This can be done by going to applications > utilities. Follow the steps in this wizard and create the partition where you want to install Windows to. It will prompt you to insert your Windows installation disk. You’ll need to insert a full installation disk, not an upgrade disk. (SP2 install disk for XP)
2.      Insert the installation disk and restart. Follow the installation wizard up to the page to select partition. Select the partition you created earlier with the Boot Camp Assistant here. Select the full format FAT32 option for the format option.
3.      After Windows installation, hold down the option button in order to get the option to boot into the Windows partition in order to complete the installation.
4.      Run the setup.exe program from leopard installation disk after Windows installation has been completed to install drivers for hardwares to function properly in windows.
