Installation of Tivoli Storage Manager
I need help with an installation process I can’t seem to complete. I’m trying to install the Tivoli Storage Manager Device Driver but I keep encountering the same error message every time:
Device driver Installation Wizard
Cannot Complete the Device Driver Installation Wizard. Errors were encountered while installing the software for your devices. See the Status column for more details.
Sometimes it helps to run this wizard again. If that doesn’t work, contact your device vendor.
Driver Name Status
IBM Corporation (tsmscsi) MediumCh…. Install failed
Back finish Cancel
I should mention I’m using Windows 2003 so if someone’s had the same problem at some point please provide some info on how to resolve this.
Thank you in advance.
