y2caye
Posted on - 12/25/2011
Every time I login to the computer an error message pops up.
The error message displays that ‘The installation of Windows Media Player is not properly done.
So it is to be re-installed.
You can install the same for MS website.’ It contains the ‘No’, Yes’ and ‘Close’ options.
This problem started after the installation of Windows Media Player.
I have re-installed the application from their website, but there was no change in the error message.Â
I am using windows XP Pro SP 2 and McAfee anti virus. Please help me to fix the problem.
I will thankful for all help and support.
Hello, you might wish to use System Restore to roll back your machine to the date when Windows Media Player was working.
If System Restore does not work, you can try the following steps to find out the cause of error.
Click Start >  Run > Type in ‘cmd’ then press Enter.Â
Type in ‘sfc /scannow’ in Command Prompt and then press Enter.Â
It will run a bit time. Be patient and wait until it is completed. If it finds any cause of error, you may fix it.
You might also wish to use System Restore under Safe Mode.
Hope this could help. Thanks and regards.
To fix this problem you will have to update the windows media player.Â
Follow the steps below :
Close the windows media player.
Go to the path Start > All Programs > Accessories.
Then Right Click On Command Prompt or CMD and Select RUN AS ADMINISTRATOR.
Click Continue or provide Administrator credentials if prompted.
In the Command Prompt window type the following command and then press ENTER.
UNREGMP2.EXE /UPDATEWMPVERSION
If this Doesn’t work, then Uninstall the WMP and Install it again.
You will have to restart the PC after Completing the process.
If you still not able to fix the problem, then just let me know.
