Installation of Windows XP SP2 error message
I have a PC with Windows XP SP2 installed on it.
It was working fine until yesterday when computer froze and a blue screen error message appeared.
When I restarted the computer all I can see is the same blue screen error message.
What could be the possible reason why this happened and what could be the solution for the problem?
I have a PC with Windows XP SP2 installed on it. It was working fine until yesterday when computer froze and a blue screen error message appeared. When I restarted the computer all I can see is the same blue screen error message.
Technical information:
*** STOP: 0x0000007E (0xC0000005, 0xF88FF190, 0x0xF8975BA0, 0xF89758A0)
*** EPUSBDSK.sys – Address F88FF190 base at FF88FE000, datestamp 3b9f3248
Beginning dump of physical memory
