To install windows 7 problem and how can I set up?
Hi Rashel,
You must enter BIOS/CMOS setup by pressing DELETE or F2 key to set CD/DVD-ROM drive as your first boot device then press F10 to save the settings.
Procedures Windows7 Installation:
1. The computer will detect the Windows7 installation CD.
2. On WIndows7 setup wizard you will need to do this steps:
– Click install now button and accept License Agreement by checking the box then click NEXT button.
– Select Custom for clean installation
– Choose the Partition1 then click OK and NEXT button.
After this procedure is done your computer will automatically restart.
3. Enter user account and computer name then click NEXT button.
4. Enter your product key.
5. You must enter time and day then click NEXT
Wait for Windows setup to finalize and launch desktop.
6. Check device manager and start installing or configuring other devices to your computer.
LauraP
Notifications
