InstallBuilder installation shows error before installing
Hello there,
I want to install the program InstallBuilder to create an installer for a little game that I’ve created. When I want to install the program this error appears and tell me to try again to install. I’ve tried many times and always the same error. Is there a solution for this error ? Please tell me if there are any others InstallBuilder.
Thanks !
X:installbuilder-professional-8.6.0-windows-installer.exe
The specific path does not exist.
Check the path, and then try again.
OK
