chrisstate
1030 points
Posted on - 07/12/2011
Greetings, While I was at home yesterday, I received a phone call form a friend asking for some help, his problem is regarding the error he meet while using flex builder, since I can not picture out his problem, I ask him to sent to me the screen shot, and the same shot I pasted below.
Installed Flash Player is not a Debugger
C:Program FilesMozilla FirefoxpuginsNPSWF32.dl
Flex Builder cannot locate the required debug version of the Flash Player.
 You may need to install the debug version of Flash Player 9.0 or reinstall Flex
 Builder. Do you want to try to debug with the current version?
As I see the error message, I thought it was just a simple flash player problem, but it involves application development, I don't have any idea on application development, what I advice him to do is to re-install all the software he is using, but still he encountered same error, please help us with this issue, I am waiting for your reply.
Hi,Â
That's mean you have tried installing again and no success. So one solution gone and just one solution remaining to solve your problem now. Follow these steps it might help you. Uninstall the flash player from your system with the help of Adobe Uninstaller. Now Download flash player 11 debugger plugin. It will be compatible browser and just download flash player only from the Adobe website. Install flash player and try to debug flex software once more. I hope the error which was causing problem won't come again.
Hope its solve your problem.
Hi.
To solve this simply click on the link provided with error massage. It will download the latest Flash player. If using Google Chrome then this is tricky. Google Chrome replaces debug with non-debug behind the scenes because it has build in flash support. Flash player debugger and non-debugger are two stand alone swf players. Also check registry for case that Flex did not swapped places with flash. That also can make error and trouble.
Queen Norman
