The installed product does not match the installation source
I just tried to install the QuickBooks software with a valid key but the error message shows the product is not matching the installation source. I could not understand this scenario. I need your proper assistance to fix this issue. Thanks.
QuickBooks
The installed product does not match the installation source(s). Until a matching source is a provided or the installed product and source and synchronized, this action cannot be performed.
Contract your system administrator or product vendor for assistance if there is a matching installation source. Type it below or click Browse to locate it.
Use Source
\    .SBSCompanyNetwork AdminInstall Apps
Answered By 0 points N/A #176026
Hi Melissa,
The cause of error message that says the product is not matching the installation source is about the registry key. In this case, the registry key of the Quickbooks which you are about to install has been damaged and corrupt. To fix the issue, you need to directly repair the error or reinstall the Quickbooks. Please click the link provided below to know more.
How to Repair Installation Source Error – This link will guide you through the official section page of the Quickbooks. It provides step-by-step instructions on How to Fix Installation Source Error.
How to Uninstall and Install Quickbooks – This link will guide you through the official section page of the Quickbooks. It discusses how to properly uninstall and install the QuickBooks.
Ware
