I need to uninstall some unnecessary programs on my Windows XP computer via Add/Remove Programs applet on the Windows Components option. Whenever I click the Add/Remove Programs applet i get this error message.
What could this error mean?
Setup library ocmsn.dll could not be loaded, or function OcEntry could not be found.
Contact your system administrator.
The specific error code is 0x7e.
qurat
Installed program now appearing in Add/Remove Programs
So when you open Windows system to add or remove programs applet the following error may occur.
To resolve the problem or extract a new copy of the file resolve the problem, follow these simple steps :
Insert the Windows XP CD in the drive.
Click Start Run and Type CMD.
Type this command given below.
Expand X:i386osmsn.dl_rC:Windowssystem32setup.
Where X is your CD-ROM Drive letter, the above command assumes that the Windows in installed in C:drive, if it is not then change the driver path accordingly.
Try this method and I hope you will get rid of this error.
Hope it will be helpful. Good luck..!!!
To access add / remove program add the registry entries that are missing:
Start>Run>Type CMD and press on Enter>In the command window type:
regsvr32 mshtml.dll and click on enter
regsvr32 shdocvw.dll –I and click on enter
regsvr32 shell32.dll –I and click on enter
Close the command window and when you try to access add / remove program you will be able to access it.
Hi good day, I will give you the steps how to fix this kind of problem.
Insert the Windows XP CD.
Click Start menu>Click Run type CMD.
In the command prompt, type this command.
Expand X:i386ocmsn.dl_-r C:windowssystem32setup
Where X: is your CD-ROM drive letter. The above command assumes Windows is installed in C: drive. If not, change the letter / Path accordingly.
Example:
Expand h:386ocmsn.dl_ -r G:windowssystem32setup.
Note: Read carefully and follow the command.
Thank you.
