Installed PuTTY and need to find TN3270 FONTS
Hi! I recently installed PuTTy at my company but I cannot find any TN3270 FONTS. Do you have any tips on how I can insert the said font? Your prompt reply would be highly appreciated.
Hi Marsha
You can use Google to search for the said font. Here is a technique to do the search. In the Google search box type filetype:xxx where filetype is the extension of file you are searching, in this case .ttf which is the extension of font files, and the xxx is the name of the file, in this case it is the name of the font you want. So you should type ttf:TN3270 in the search box. The search result will show the download for the font file you need.
After you download the font, copy it and paste it into the Fonts folder which you can open in the control panel.
