Installed slide cuber messed up my slideshow images
My installed slide cuber messed up my slideshow images. I recently purchased a license and installed it however, when I tried to plug it in my images are cropped at the upper portion. Please help.
Best Answer by LyanaHay
Answered By 0 points N/A #137259
At the bottom of the cManager, you will notice the slide property bar. There, you will find several options like image align and offset and image transform. These options will help you to adjust the size and position of the image and will solve the issue of cropping, that you mentioned in your query.
Answered By 0 points N/A #137260
 Here is a solution for your problem:
1)  Choose cuber project for editing.
2) Click on edit from action panel.
3)  Select use posts images section and get access to the settings
4) From setting choose inside/ outside/ use of post to get post image fit
This thing will solve your problem.
For more information on it you may check the support site for cuber project
Here : http://support.getcu3er.com/home
