Installed Zoho Plugin For MS Office Error running Program
Hi experts,
I’ve just installed Zoho plugin for MS Office. But when I try to run this, an error message appears.
I also get this message if I want to open or add a document in it.
Erreur de script dans Internet Explorer : Une erruer est survenue dans le script de cette page. Ligne: 25 . Caractere: 46 . Erreur: 'J' attendu . Code: 0 . URL: https://www.zoho.com/  Voulez-vous continuer a executer a executer les scripts de catte page?
Thanks in advance:
Answered By 590495 points N/A #113507
If this is the first time it happened upon using Zoho plugin for Microsoft Office, try restarting your computer then try it again. If it still doesn’t work after a system reboot, you should check again the program’s necessary requirements.
Maybe you forgot to install an additional supporting application to make the plugin work properly.
Zoho plugin for Microsoft Office works with Windows XP, Windows Vista, and Windows 7. If you’ll be installing it under Windows XP, you need to install Microsoft .NET Framework 2.0.
And you also need to check if you are using the appropriate version of Microsoft Office. Zoho plugin for Microsoft Office can be used as plugin for Microsoft Office 2003, Microsoft Office 2007, or Microsoft Office 2010.
