judithmads
980 points
Posted on - 08/03/2011
Hi friends,
I have an issue here, this is all about my hard time in installing Live Mesh, while I am on the process of installing Live Mesh to my computer, I meet an error message, the error message goes like "Installer encountered errors. Error : 80004002".
Live Mesh
Error : 80004002
When that error message appeared on my screen, honestly I had a hard time understanding it, because of how it was stated, but when I try to understand it, the bottom line is installation failure. Because of that, I get another copy of the installer and when I try to install it again, same error message appears.
Please share your experiences on this error message.
Hi there,
The Live Mesh Error8000402 means that the program was damaged. Maybe some of its files were corrupted.
But there is no need to worry because this can be repaired.
I suggest that you repair this program through repair utility from this link:
Download and install the repair tool.
This will help you to diagnose the issue on the program and bring out the appropriate treatment to the problem which can fix your computer.
This is a Microsoft issue.
You need to keep all your Microsoft products updated with all hotfix and Microsoft released special tools.
So that, you are always safe and your system runs smoothly.
Now please follow the link.
After applying this, your mesh install will start normally.
