ronald luna
20 points
Posted on - 03/23/2012
The installer integrity test has stopped working. The main reason is including the unfinished download and injured media.
Make contact with the installer's author to get a new copy.
Please help.
Thanks a lot.
Installer integrity has stopped working
I think your problem here is with your installer. The usual problem with an installer is a damaged file, corrupted file, or sometimes would result to an invalid directory when extracting the contents of the installer’s archive. This problem is common to downloaded installers.
This problem is sometimes caused by an incomplete download where you sometimes get the error invalid directory or archive is incomplete. If this is the case, try downloading the file again from its official web site so you can be sure that the file is really working.
You are getting the installer integrity error because your archive file is incomplete or damaged. Try downloading the file again.
