Installer for Jalbum has stopped working
Hi guys, I have a problem here in my post to share with you, I am having a hard time installing Jalbum, right in the middle of the installation process an error occurred, with a message Installer for Jalbum has stopped working, see below the full context of the error.
Windows can check online for a solution to the problem.
→ Check online for a solution and close the program
→ Close the program
View problem details
As I analyzed the error message above, this is about my installer, so I downloaded again with a new installer, before I install it I check for some virus of the new file, none was found, so I install it again, and same error message appeared, please help me guys solve my issue, thanks.
