Installing 64 bit system onto a 32 bit without formatting
Posted on - 02/07/2015
I have a 32 bit system that I wanted to upgrade to 64 bit, the problem is that I have large files that I consider not to loose in partition C and I wanted to know if there is way to upgrade without necessarily formatting the entire drive? Can the upgrade work with all the associate window programs like media player?
