While I'm installing my Flash Player, this error appears and I can't continue my installation.
I try to download again the installer, but this error keeps on appearing.
Thanks for your Help
Installation encountered errors
Failed to initialize
CODECATCHER.BLOGSPOT.COM
Installing Adobe Flash player always fail
Hi Adam,
Try to close any open browser while installing Adobe Flash Player.
Solution: Try changing the date of the computer to the current date,
By changing the date to current date maybe your problem will be fixed and try to download the updated version from Adobe Official
Web site.
Adobe Flash Player link.
Before installing the Adobe Flash Player make sure to uninstall the previous version first.
Hope my solution fixes your problem
Larry 😀
It’s a big problem indeed. Well, you can try these steps to solve your problem-
1 Download the current 32-bit Uninstaller
2 Close all browser Windows and run the Uninstaller.
3 Restart Windows.
4 Verify that the file “FlashPlayerCPLApp.cpl” in C:Windowsystem32 has been deleted.
5 Download the installer.
6 Close all browser Windows and run the downloaded installers.
Hopefully, it will work.
