Installing And Updating A Driver For Dell 2155cdn Software Download
Please, can someone list down the steps to download and update driver Dell 2155cdn software download?
A driver is an essential program which enables your PC to communicate with the hardware device for which the driver is downloaded. As an example, suppose you want to print a page, then your PC will talk with the printer through the driver. The hardware device will not work acceptably if there is no driver. Also, there are different drivers for different operating systems.
A list of links to download drivers is given below-operating system wise-
1) For Microsoft Windows XP:
• Scanner driver: Download from here
• Fax driver: Download from hereÂ
• PCL print driver: Download link
2) For Apple MAC OS:Â Download link
3) For Linux OS: Download link
4) Windows Vista (64-bit):
• PCL print driver: Download from here
• Color printer driver: Download from here
5) Windows Vista (32-bit):
• Scanner driver: Download link
• Fax driver:  Download link
• Color printer driver: Download link
6) Windows Server 2008 x86:
7) Windows Server 2008 x64:
8) Windows Server 2003 x64:
9) Windows Server 2003:
10) Windows 8 (64-bit):
11) Windows 8 (32-bit):
12) Windows 7 (64-bit):
13) Windows 7 (32-bit):
14) Windows 10 (64-bit):
15) Windows 10 (32-bit):
If you need the driver software for your Dell 2155cdn printer, go to Support for Dell 2155cn/cdn Color Laser Printer to download. This driver software is for Dell 2155cn and Dell 2155cdn printer models. Here, select your correct operating system. The drivers available are for Windows XP, Windows Vista, Windows 7, Windows 8.x, Windows 10, Windows Server 2003, Windows Server 2008, Linux, and OS X.
Download and install all available drivers and software for your printer. Downloads include the Dell printer software suite, the firmware update for your printer, some imaging tools, and the required drivers for the device’s printer, scanner, and fax features.
