joan d vogt
10 points
Posted on - 09/19/2012
How do I uninstall other Antivirus Software before I can Install Trend Micro Titanium 2012?
It seems that Nod32 is still shows installed after I uninstalled it! I have tried restarting it because I thought, maybe that was the only solution because sometimes when I uninstall programs they ask me to restart, but the installer thinks Nod32 is still installed!
Incompatible Software Found
Before installing the program, the installer must first remove the following incompatible software from this computer.
Do you want to let the installer automatically remove this software for you?
Installing Anti virus in system
Hello.
It seems that you did not uninstall the antivirus completely.
Try to uninstall the antivirus completely.
As shown in the screen shot by you allow the trend micro to uninstall the software completely.
Check in the program settings whether there is any other software related to nod 32 is available.
Contact customer support for further support.
Thank you.
Hi Joan,
It is not at all recommended to have two or more antivirus programs installed at the same time. You should always keep just one anti virus program installed on your computer at a time.
You first need to uninstall NOD32 from your system. This can be done by going into Control Panel and click on "Add or Remove Programs". Once uninstalled, try installing Trend Micro again.
This should solve your problem.
Hope this helps!
Drianna allen
