I have completed the installation process but it showed me error message without showing success message after installation. Why this happened?
Avast internet security setup
Set up finished
There was an error while completing the setup process
view setup log
Installing Avast antivirus shows problem message
Dear User,
The only way you can fix this problem is,
Uninstall Avast from control panel First
Now reboot your system.
Then go to this link and download the latest version of Avast Uninstall and fully uninstall Avast from your computer using this tool
https://www.avast.com/uninstall-utility
now try to install Avast again. And try the latest version of Avast.
Thank you
Please uninstall the current version of Avast from you system, then reboot.
Re-install the Avast and let it connect to internet whenever is required.
Hope this would make your work success.
If problem persists, try to use a different version of software and then upgrade it to the latest version.
