I need instructions on installing brushes in Photoshop. There are times that it did not work while using the drag and drop option. How can I download it and add them to Photoshop Library? And what are the steps to use those downloaded brushes in Photoshop?
Installing brushes in Adobe Photoshop
It is really so easy to install brushes in your Photoshop. If you download brushes from any website, then maybe it is in a file like .zip or any compressed file then uncompress it.
You will find a file with “ .abr “ extension. Place that file into program file > Adobe > Adobe Photoshop > preset > brushes. Now you can make a brush on your own. So if you want to make a brush on your own, then create it in a transparent new document. Then click on the edit menu and click on the define brush preset to make a new brush.
