Installing Fonts to Mac Powerbook
We can install fonts on to MAC OS also. But it is little tricky process you need to follow the steps carefully.
MAC supports two types of fonts i.e Type 1 and openTypes fonts. The location varies if you want to install the fonts for a specific user.
If you want fonts to be installed for a specific user you need to copy the fonts top /Users/Library/Fonts directory. If you want to install the fonts to all the users you need to copy fonts to /Library/Fonts directory.
You can use the available fonts management tool which will install the fonts to your system. The above ways will not work for Classic OS but it will work for rest all OS's.
Hello James,
Installing fonts on Mac is very easy. You will need to use the following procedure:
Carl
