Installing game in Android tablet
I have my Android tablet. I want to install a game which is the temple run. I found out that there is an application of this game that can be installed in android. However, when I install it, it doesn't work. Why is this so? Can anybody help me on installing this game to my android?
Answered By 0 points N/A #153803
There are devices that are not supported especially if your device is older. You will need to update your firmware. Check on your settings if there is an available update. You can do it over the air or through Wi-Fi or 3G connection. It will also be nice if you mention which tab are you using so we can look for an update and a link to download the Temple Run game. You can also click on the link below and find something that might be helpful for you:
Temple Run for old Android Devices
