Installing Helix MP3 codec has crashed
I have installed version 14 references and uninstalled the registered version 12 on my computer. Installing Helix MP3 codec has crashed and gone into an endless loop but before that I was able to add wmv. MSVCP71.dll is missing from your computer; and the program can’t start are the error messages appearing. To fix this error, I have tried reinstalling the program.  What reason does this error come from?
Error:
The program can't start because MSVCP71.dill is missing from your computer.
Try reinstalling the program to fix this problem.
Answered By 5 points N/A #103152
Good Day
You should keep in mind that, the default location of the msvcp71.dll must be: C:Program FilesHPQuickPlayMsvcp71.dll. Now, if you can’t locate the file here or find it in another location, then it must be mistakenly eliminate from the computer or infected by PC threats. Viruses or malicious threats are able to severely destroy and remove the Msvcp71.dll from your computer to bring in the PC errors.
Besides, they can also disguise themselves as the legitimate file on the computer and do whatever it wants. At this time, it will be very difficult for you to identify and remove them with your naked eyes. So, do remember to download and run an antivirus anti spyware program to detect and remove all PC threats from the computer immediately. By the way, to real time protect the computer; it is highly advised that you should let your computer protection program always running in the background.
Secondly, if you find that the msvcp71.dll error message appears soon after you uninstall a program, restore your computer to a previous state with your backups or you can simply copy msvcp71.dll file from another computer with the same operating system and then place it on your computer. Also, you can download msvcp71.dll file from a trusted website and then place it on the computer. By placing the missing or broken msvcp71.dll file on the computer, you can sometimes solve this PC error. By the way, this also helps to solve dll errors that cause by a mis-deletion of the msvcp71.dll file.
Those are the common causes and solutions for the msvcp71.dll missing error. According to the experts’ advice, it is best that you can keep on doing these steps in your daily computer life to prevent the msvcp71.dll error before it brings in some damages to the computer.
http://www.dlldownloader.com/msvcp71-dll/
I hope this information helps,
Mark Amna
