Hello pals!
Does anyone of you know the method to install device driver for my HSDPA card by ZTE on Leopard OS.
It worked just fine on Microsoft windows but I find myself in no luck installing it on Leopard.
I even tried to download the driver setup from company website but nothing helped.
If anyone have a solution please tell me. The following error occurs on the screen:
Install INDOSATM2
Installation had errors
The installation failed.
The following install step failed: run preflight script for INDOSATM2. Contact the software manufacturer for assistance.
Installing HSDPA Card by ZTE on Leopard OS
Hi there! Here are the steps on how to install your HSDPA Card by ZTE using a Leopard OS.
First download the updated MF112 Drivers from Vodafone.
After you have installed the latest version your modem will be added to your Network Services in the System Preferences > Network.
Once you connect your dongle and run the Setup Software, the device should now be recognized and will finish its configuration.
The next step in deleting the software files of Vodafone in your applications folder. Please do not uninstall the software or you will lose the new drivers as well.
You will see an antenna icon in the menu bar that is from the Vodafone Software if you want to disable it, before deleting the software you just simply change the settings in the Vodafone software.
