Installing the latest youtube for pocket pc cab for HTC
What are the steps performed to install the latest YouTube for pocket pc cab file formats for HTC mobile handset and how do I get updates of the latest cab releases?
Hi there user:
Just go to the Market Application of your HTC mobile handset, particularly Zune Marketplace. On the search box, type YouTube Application. Download the YouTube application and then install it into your unit. Also you can download it using your computer (Windows 7) by way of this link http://jaxov.com/2010/12/download-youtube-app-for-windows-phone-7-htc-phones/
Thank you for asking.
Best regards,
Hi Nimbus
The answer to this question is as simple as the question itself. If I am not wrong, you need to know how to install the most recent YouTube for pocket PC CAB file formats for the HTC mobiles. Let me guide you step by step in how this has to be carried out.
1. First you need to download the application into your system and then transfer it to your handset, or you can directly download it to the mobile device.
2. Once the file is transferred to the mobile device then, you need to open up the file explorer, if it is in windows platform, then the file explorer will be located under the programs menu. For android it will be located in the menu itself.
3. Select the file and then you can run the application, this will take around 2-5 minutes to download into the device.
4. Once this is done then you can restart the device, and you are good to go.
5. You don’t have to worry about the updates for the same, the application has a built in feature where it will automatically search the web for updates and it will install automatically.
6. You can also view the following video on you tube so that you can gather extra information on the same.
Bell Keny
