I have a question , I will soon obtain an iPhone using Verizon will our administrator need to install the software for Lotus Notes Traveler on our server previously to me installing Traveler Companion? I was informed I need to use Traveler to be able to push contacts, calendar and e-mails to an iPhone. My administrator is unfamiliar with the Iphone, so I informed my admin to do this. Is this correct way?
Also is there any other possible way to do this?
Installing Lotus Notes Traveler in iPhone
Hi Stewart
If you are already using Lotus Notes Traveler, it should be a problem. Once you have the new iPhone, please follow the steps below to sync iPhone and the Lotus Notes Traveler:
Check the Lotus Notes Traveler Administrator and it must be running Traveler 8.5.1.1 or greater. Traveler Companion of iPhone will only work with the greater versions of Traveler.
Download the Lotus Traveler Companion application from iTunes or you can go to this link:
After installing the application in your iPhone, you are good to go.
I don’t think that you will need an expert to do this. If there are problems found, you can report it on Wiki listed in the App Store support URL.
Hope you will find this helpful.
Cheers
