gopaldas17
Posted on - 09/18/2011
Hi!
I am facing problems with installing microsoft 7 in ubuntu. I also tried wine to install but it gives the error ".exe file cannot be opened".Is there any other way to install. I tried from the terminal but it doesn't works.
Thanks,
Sam
Valent
Installing Microsoft office 7 in unbuntu ?
Did you mean Microsoft office 2007? 🙂 It can install to Ubuntu using wine. We must use wine 1.3 because it includes winetricks. Now see these tips:
Download and install msttcorefonts-offline here:
Now add wine's ppa address to repositories: sudo add-apt-repository ppa:ubuntu-wine/ppa.
Install wine with this command: sudo apt-get update && sudo apt-get install wine1.3.
After it installed, run wine from terminal.
Pick component to install: msxml3, dotnet20, gdiplus, riched20, riched30, and vcrun2005.
Follow the guide to install Microsoft Office 2007 until the end.
Now you have Microsoft Office 2007 running on Ubuntu.
Hello Gopaldas,
You can easily install Microsoft Office 2007 in your Ubuntu operating system if you correctly follow the steps mentioned below:
1- Install the latest version, please make it sure that you have the latest version of WINE running.
2- Configure Wine -> Application -> Wine -> Configure Wine for windows version
3- Now install Microsoft Office 2007.
You will be able to run Microsoft Office correctly with no more errors.
Thanks
