Installing Microsoft word and Anti-virus on the Android
Microsoft Word is not yet available on Android as of the moment. However, you can install Quick Office which will let you view and edit MS Office and PDF Documents. Some Android Devices are pre installed with Quick Office, if your device doesn't have it just to android market and purchase it. Antivirus softwares are also available in Android Market just type in AVG or Mcafee on the search box and it will come up with several antivirus softwares to choose from.
I think I may have found the perfect software for you since you want an application that you can use on your Smartphone for opening and editing documents and files created from Microsoft Office Word. You can use Documents To Go to open, edit, and or create files from Microsoft Office Word, Microsoft Office Excel, Microsoft Office PowerPoint, and Adobe PDF right from your Smartphone.
Here are some of the key features that you can expect from Documents To Go.
To access the complete information and to download it as well, you may visit Documents To Go. And since you are looking for an antivirus to install on your Android phone, here are the top 5 antivirus applications that you can use on your Android Smartphone which you can download by visiting this link:
http://refugeeks.com/top-5-antivirus-apps-for-android/
