Installing MS Office Document Imaging With Windows 7 Professional:
Hello. I am currently using Windows 7 as my Operating System. How do I install MS Office Document Imaging without having to install Microsoft Office? How do I deal with the MODI exe for Windows 7?
Answered By 0 points N/A #299151
Hey. The MS Office Document Imaging is not a part of the Microsoft Office 2010. It is highly recommended that you update your current Operating System. You can get it back for your Windows Operating System easily by adding to your Office. This can be done easily by downloading and installing MDI to TIFF File Converter. To download the file converter visit the Microsoft Product site. You can also visit the following link to download the same.
http://www.microsoft.com/en-us/download/details.aspx?id=30328
(OR—>Alternative Answer)
Hello. You can use the MS Office Document Imaging with the 2007 Office System Media.
  • Setup the 2007 Office System and accept software license.
  • Choose “Customise
  • On the “Installations Options”, choose “Not Available”.
  • Expand “Office Tools”.
  • Choose “MODI” and run from your computer.
  • Install the files.
