INSTALLING OF NEW OPERATING SYSTEM WITHOUT CD ROM
Hi I am spooky and I use one of the hp intel atom notebooks. There is no cd rom attached to the notebook. To reinstall windows on my notebook I need to use a cd rom but I don’t have a cd rom.so what do I do?
Best Answer by estrebillo
Answered By 0 points N/A #128475
Try Using Bootable USB pen drive..
This link show you to how to create a bootable USB using wintoflash application..
Answered By 0 points N/A #128476
There are to ways to solve this problem:
1. Use flash disk or external hard disk. Copy the contents in the installation CD to the flash or external hard disk using another computer that has CD or DVD ROM. Secondly; enter the computers BIOS and set flash disk to be the first boot.  After starting the pc press on delete button or F10 to enter bios. Navigate to Standard CMAS features press enter, change the setting of the first boot to flash or external hard, click F10 to save and exit. This will enable you to install the windows again in your pc. Restart and press F8 consistently and the many option will come on the screen and choose install option
2. You can also use the hard drive in the pc. All you have to do is change BIOS setting on first boot
