Installing One Note with my XP
Hi. Is it possible that I will install OneNote 2007 with my XP Office 2003? If I will install it while running during the installation, is the OneNote 2007 will cause error and software problem with the computer? If I will install it, will it affect my other software applications? Are there any steps to properly install it right?
Answered By 0 points N/A #98004
I believe that there will be no problems installing One Note 2007 with a Windows XP system. Just make sure that your Windows XP is updated to the latest service pack which is service pack 3. Also follow minimum system requirements like hard disk space and minimum RAM requirements. Just follow the onscreen prompt when installing the software and you should be good to go. Also update your One Note 2007 application through Windows Update to avail of the latest updates and features. Also, it will provide fixes and performance updates to the application. Windows Update will also update One Note to its new version of SP1 if you update it.
