alec hughes
20 points
Posted on - 03/09/2012
Hello everyone,
I have been into some serious problem while installing remote agent on my computer.
I have Leopard OS currently running on my system, and whenever I try to install this it leads to the following installation failed error.
I even restarted my computer, but this does not help.
Please help!
The installation failed.
The installer encountered an error that caused the installation to fail. Contact the software manufacturer
for assistance.
Installing ReadyNAS Remote Setup in Leopard OS
Hello Alec.
Please include the following info with your post:
- Leopard OS architecture (32-bit or 64-bit)
- Version of ReadyNAS Remote that you are trying to install
I assume you are not using the latest version of ReadyNAS Remote.
The old version had issues running on the 64-bit kernel.
A common workaround is to restart your Mac and press the keys “3” and “2” (which stand for 32-bit) while it is booting up.
This forces your OS to load in 32-bit mode instead of the default 64-bit mode.
On the 32-bit mode, ReadyNAS will install and work properly.
You can download the latest version right here:
The installation instructions can be found here:
How to setup remote access with ReadyNAS Remote : ReadyNAS Community
