peter33
Posted on - 09/13/2011
I have a problem to install RealPlayer in my computer using Linux Debian and i need your help to handle what is happening
I always have this error "could not launch menu item"
I found some information in a document but it didn't work
please help
Error
Could not launch menu item
Failed to execute child process "realplay" (No such file or directory)
OK
Installing RealPlayer with linux debian
First of all you need to log in as administrator in your computer. Then your operating system give you this kind of opportunity to install various software such as real player. So first you need to be a root user. Then write the root location of excitable file perfectly.
This error shows because your root excitable file is not there. May be you moved that on other location. Use that location to open this file. Or may be you are giving wrong address for root folder. Make sure what your installation root folder’s location is. Then copy that location and paste it on your address bar.
