Is there an easier and faster way of installing Samsung Galaxy S3′s TouchWiz UX Launcher to S2?
Installing Samsung Galaxy S3′s TouchWiz UX Launcher to S2
Requirements
A rooted Samsung Galaxy S2 running on an AOSP, AOKP, or CyanogenMod 9 custom ROM and with ClockworkMod
Recovery installed.
Check our guide on how to root the Samsung Galaxy S2 GT-I9100 and install ClockworkMod Recovery.
Backup all personal data on your phone to make sure you have a copy of your personal data (e.g., contacts, SMS, MMS, Internet settings, Wi-Fi passwords, and the like) in case the procedure in this guide erases such data.
For backup tips, check our guides on how to sync your data to the cloud and how to create local backups of your mobile data.
Download the TouchWiz UX Launcher package (TouchWizUX-180dpi,240dpi – by XaToR 1.1.zip, 2.1 MB).
Then try
Copy the TouchWiz UX Launcher package to the root of your Galaxy S2′s internal SD card.
Turn off the phone.
Boot into Recovery Mode by pressing and holding down the Volume Up, Home, and Power buttons. When the screen turns on, let go of all three buttons.
Select Install ZIP from SD Card.
Select Choose ZIP from SD Card and select the TouchWiz UX Launcher package.
After installation is complete, select Go Back.
Select Reboot System Now.
