iimrank
Posted on - 01/25/2012
When I try to install silverlight 2 on my computer it shows that the computer already have silverlight installed but it is not listed in `add or remove programs ’ or `windows installer clean up utility, I tried installer.exe to run the silverlight, but failed. And now, I need to remove silverlight keys from the registry and how do I do that?
Installing silverlight 2 it says already exists
Type Regedit in Run and press enter.
now select Find from the Edit menu
and enter name of the software you want to delete from registry
After searching it will display a Registry Value
Delete that file from Registry and Restart computer
But deleting manually from registry require very attention deleting wrong file from registry may affect your system.
Therefore i recommend you any Registry cleaner Software to clean registry very easily
Wise Registry Cleaner is a free registry cleaner software available on internet.
download and install it
run Wise Registry Cleaner and clear registry in a second.
Silverlight is a software that you can access media files and other 3rd party software. Think you need to update your windows operating system and reinstall the new updated version of Silverlight and use cleaner to clean registry in your operating system is vital to always clean your registry so that unused program be cleaned.
Hello Iimrank,
It seems that your previous installation of Silverlight is stuck in your computer is operating system. You mentioned that it doesn't appear from add/remove programs already.
Here is my suggestion but be careful in following the procedure as you may encounter fatal error deleting unwanted keys.
1. Go to registry error
Vista – click Start, type “regedit” on the Search box and press enter
XP – click Start, then Run and type “regedit” and OK
2. Find the key HKEY_LOCAL_MACHINESOFTWAREMicrosoftSilverlight and select
3. Choose delete on the edit menu, and yes to confirm
4. Click Exit on the file menu to exit the editor
5. Reinstall your Silverlight
I hope this help you.
