Hi, I’m using Windows 7 on my PC. I want to install any software for my android phone.
But there is an error message that appears.
I have also tried rebooting; it doesn’t work to get the program to load completely.
doubleTwist Setup
Installation Aborted
Setup was not completed successfully.
Execute: C:UsersOwnerAppDataLocalTempApplication.exe
Downloading Bonjour
Do you have suggestions?
Installing software in Android phone
Hi Laurel!
There seems to be a problem in downloading in the Bonjour component of the installation process.
To fix this try to follow the steps below.
Method 1
Try to download Bonjour separately here
Run the executable file and follow the Wizard Instructions there.
Install doubleTwist again.
Method 2
Go to start and in the search box type%temp%
Empty the contents of the temp folder by deleting it. Make sure that Application.exe is removed.
Method 3
Update your .NET Framework by downloading it here.
Run the executable file and install.
After the installation is finished, try to install doubleTwist again.
