Installing SRSDataconnector in my new SQL Server 2012
Whenever I go with installing SRSDataconnector in my new SQL Server 2012 for CRM2011, the following error occurs.Â
Rollup 6 is included within my installer. Here follows the problem related part of the log file.Â
Does anyone of techyvalley.com say what the problem is?
I am in a great trouble with this. To speak the truth, I can’t work for this problem.
Please help me.
16:23:41|Â Â Info| Executing Install action: Microsoft.Crm.Setup.SrsDataConnector.RegisterServerAction
16:23:42|Â Â Info| Adding server INTERNALDB3 to configuration database with role SrsDataConnector
16:23:42| Error| System.Exception: Action Microsoft.Crm.Setup.SrsDataConnector.RegisterServerAction failed. —> Microsoft.Crm.CrmException: Column 'DatacenterId' does not exist on table Server
  at Microsoft.Crm.SharedDatabase.DatabaseService.CheckColumnSetColumns(PropertyBag columnSet)
  at Microsoft.Crm.SharedDatabase.DatabaseService.Create(String tableName, PropertyBag columnSet)
  at Microsoft.Crm.Admin.AdminService.CrmServerService.Create(String serverName, Guid scaleGroupId, Guid podId, Guid datacenterId, ServerRoles roles, ServerState state)
  at Microsoft.Crm.Admin.AdminService.CrmServerService.Create(String serverName, Guid scaleGroupId, Guid podId, ServerRoles roles, ServerState state)
  at Microsoft.Crm.Setup.SrsDataConnector.RegisterServerAction.Do(IDictionary parameters)
  at Microsoft.Crm.Setup.Common.CrmAction.ExecuteAction(CrmAction action, IDictionary parameters, Boolean undo)
  — End of inner exception stack trace —, Error, RetryCancel, Option1
16:41:35|Â Â Info| InputResult: Cancel
16:41:35|Â Â Info| CrmAction execution time; RegisterServerAction; 00:17:54.7783702
16:41:35| Error| Installer Complete: SrsDataConnectorInstaller – Error encountered
16:41:35| Error| Install exception.System.Exception: Action Microsoft.Crm.Setup.SrsDataConnector.RegisterServerAction failed. —> Microsoft.Crm.CrmException: Column 'DatacenterId' does not exist on table Server
  at Microsoft.Crm.Setup.Common.Installer.Install(IDictionary stateSaver)
  at Microsoft.Crm.Setup.Common.ComposedInstaller.InvokeInstall(Installer installer, IDictionary stateSaver)
  at Microsoft.Crm.Setup.Common.ComposedInstaller.InternalInstall(IDictionary stateSaver)
  at Microsoft.Crm.Setup.Common.ComposedInstaller.Install(IDictionary stateSaver)
  at Microsoft.Crm.Setup.SrsDataConnector.SrsDataConnectorSetup.Install(IDictionary data)
  at Microsoft.Crm.Setup.Common.SetupBase.ExecuteOperation()
16:41:35|Verbose| Method exit: Microsoft.Crm.Setup.SrsDataConnector.SrsDataConnectorSetup.ExecuteOperation
16:41:35|Â Â Info| ActivatePage(FinishPage)
Microsoft Dynamics CRM Reporting Extensions Setup
Action
Microsoft.Crm.Set.SrsDataConnector.RegsterServerAction
failed.
Column 'DatacenterId’ does not exist on table Server
Retry Cancel
