noel leal
10 points
Posted on - 01/12/2012
I installed the latest windows 7 trial thinking I could create more folders. After the installation it works great but, for now, my entire system is crawling. Even the resizing of my windows takes time. Is there anything else that I should do before I decide to uninstall this latest trial?
Installing Windows 7 Trial Caused My Entire System to Slow Down
If the system started slowing down after you installed the windows 7 trial, then the problem is occurring possibly because you do not have enough memory to support that operating system. You will notice that the previous versions of windows like windows XP and windows 2003 were much smaller compared to the latest versions like windows XP and that means that the latter will require more memory to run properly on your computer. Therefore you will need to upgrade the RAM capacity of your computer for windows 7 trial to run faster. Windows 7 will run well on a RAM not less than 3 GB.
-Richards Gabriel
