anonymous
7060 points
Posted on - 08/05/2011
When I am installing Yahoo Messenger in my computer then I am facing a problem that is after 60% or 70% installing its appear installation unsuccessful.
Try again.Â
I want to install Yahoo Messenger.
How can it possible?
Installing Yahoo Messenger in my computer
Sometimes the software package is corrupted on that website from where you download it and it causes problems like it stop installing after some percentage.Â
I would like to refer you to download a fresh copy of yahoo messenger software from a trusted download site such download.com, softpedia.com or brothersoft.com etc.Â
After downloading a fresh copy of Yahoo messenger just run its setup and I hope that it will install on your computer without any error.
Drothy
Hi!Â
Sometimes there is a conflict amount the software's installed on our computer means some files don’t match their specification on a specific operating system. Due to which the installation process may be terminated after being completed for a small or high percentage.
In this case we have to either make changes in the registry which to a great extent a typical task or the ultimate solution for this to reinstall operating system. Some viruses are also designed for the purpose of such problems which hinder the process of installation of new software's over the PC.
I recommend you to reinstall windows and login by administrator and then try to download your required software.
Hope it works.
